sometimes i'll notice that the audio is slightly off with the movement of the lips, but most of the time it's ok. i verified this on 2 players that i have. but when i play the encoded file on my pc with powerdvd or pop in the disc into the cd-rom drive, in the same scenes the audio matches up fine. so i'm wondering then, is this a normal thing with playing movies burned yourself on dvd players and that others have come across?
Hi hyena77,
You don't specify whether it's a VCD, SVCD, DVD etc. disk that you're referring to so I'll comment on my experience, if it's any help...
I started out making SVCD's and was getting constant audio lagging video when played on my Toshiba SD220e DVD stand-alone player. Turns out it was the player (see comments under the player's review on this site for details) when combined with the (common) software I was using to create the SVCD (VCDEasy).
I now make DVD-R's from home DV AVI and have no problems.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
As hyena says and have you also tried varying your media and or burning speed ?
Newbie here needs help syncing audio to video
By blackwaterstout in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2010, 07:19 -
Visually Syncing Audio with Video
By gonzalu in forum EditingReplies: 11Last Post: 17th Mar 2009, 19:18 -
Audio Syncing issue
By jmclean69 in forum DVD RippingReplies: 15Last Post: 4th Feb 2009, 15:34 -
Mini DVD's Audio/Video not syncing after being ripped
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 29Last Post: 4th Sep 2008, 16:09 -
Syncing spearate audio/video: Better to stretch/shrink video than audio?
By stantheman1976 in forum EditingReplies: 15Last Post: 16th Jan 2008, 04:14
