Hi all, im using the Winfast TV2000 Expert card and so far so good.
the best capturing i have done has been using VirtualVCR (the amended version).
However, I cannot for the life of me get VirtualDub to capture, ive gone through all the guides and tutorials but when I try to change the capture resolution to 104x576 it says it isnt supported (but i can capture at this with virtual vcr).
Then when i try to capture, it says not enough memory (for video buffer???), or something along those lines.
Any suggestions?
My system is a P4 2.5Ghz with 512 Mb and similar spec throughout.
Cheers.
me either
Can't use VDub on anything bigger than 352x240
I think it has to do that the card uses WDM drivers and VDub uses VFW
tried using the wraper but it didn't work for me.
I also use VirtualVCR. What is the "amended version"? -
The amended version is available from the tools section (under virtual vcr) on this site.
I think its just got a slight tweak in it so that it works with the winfast 2000 card. -
I think to capture at higher resolutions, you need the wrapper (Vdub won't even recognize it without it) and the btwincap drivers. I am not sure why it won't capture at lower resolutions. There are some new drivers on Leadtek's site, but I don't know what they fix. Since my setup works for me, I haven't tried them. I use Winfast PVR. I only use Vdub to do some minor clipping and filtering.
Yeah the Leadtek drivers don't play well with Virtualdub or VirtualVCR. However the btwincap drivers work like a charm. I capture with VirtualVCR or Vdub @ 720x480. The drivers wont work with the Leadtek PVR software though. I gave up on the Leadtek drivers and software since the PVR program tends to drop frames even on a decent system.
where do i get the btwincap drivers?
will they work with my winfast tv2000(expert) card? -
http://btwincap.sourceforge.net/
Won't work with 98. I think the Expert card use a different chip, so it will not work with BT. But I think the expert card works fine with vdub without it. -
Just bought/installed the Leadtek tv2000 xp deluxe and have been playing with different caps,etc.
Since I want to be able to burn later to dvd (option) most have been mpeg2 codic but under audio it shows mpg-1 layer-2 using 44.1mhz and not 48 which I thought was necessary to be compliant, anyway ulead MF-2 will not burn dvd from files without re-encoding. YES, I have the box checked for "do not convert compliant files"
I downloaded the latest drivers and pvr software from site, files dated 12-31-2003
over the night I tried scheduled directburn dvd-ntsc and now have coaster that shows as audio disc
running w98se fat32 file sys so limited in file size, formats that will do 2 hr movie
Question about Winfast card & Hauppauge software ??
By VEBouto in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 10:03 -
VirtualDub & VirtualDubMod Error Messages..R & R
By sandman423 in forum EditingReplies: 4Last Post: 18th Oct 2007, 05:30 -
Help: No sound at all with a Winfast TV2000 XP Deluxe
By Deathwish238 in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2007, 12:01 -
Problem with WINFAST TV2000 XP Expert tv capture card.
By trueman in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2007, 11:00 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 13:22
