Hi,
I need help to back up Band of brothers cos when I did the first disc using dvdshrink and Nero when I played it on my Xbox--and later my PS2--I found that the Warner Bros. splash screen (the Warner Bros. Logo with clouds in background) doesn't appear and the disc would either not respond or pop straight to the main menu. When I tried it on my DVD-ROM the Warner Bros. logo would stutter and it would freeze PowerDVD, I played it through my DVD-RW and the splash screen would work normally.
I burnt it to a DVD-R brand called Media Cache (if that helps).
I have no idea what's going on here.....can anyone help?
Results 1 to 15 of 15
"Night Stalkers Don't Quit" - Regiment motto of the 160th Special Operations Aviation Regiment (Airborne)
Is there a better way of fixing this problem? Is it possible to remove the Warner Bros. splash screen and make it go straight to the main menu?
"Night Stalkers Don't Quit" - Regiment motto of the 160th Special Operations Aviation Regiment (Airborne) -
Do a search called Band of Brother or Gangs of New York. They will show you what you need to do. I hope this helps
Never heard of a disk brand called Media Cache. Usually these off-the-wall media brands are crap disks, like Princo or CMCMAG or something. I wouldn't be surprised if the problem is this media. Try something name-brand, like TDK or Maxell or Fuji. Don't use Memorex DVD-R. They are made by CMC.
Ok, I will try the more "reliable" brands like you said. I also updated the burner's firmware so hopefully that will make a difference (hopefully a positive one).
Wooo Hooo! Success I managed to get the Warner Bros. logo to appear.
I updated the burner's firmware and I burnt the DVD to a TDK DVDR47EA disc and it works perfectly now.
My confidence in buying a DVD burner has risen completely."Night Stalkers Don't Quit" - Regiment motto of the 160th Special Operations Aviation Regiment (Airborne) -
I dunno if that's the case in the USA or anywhere for that matter. I own the boxset and I now feel really happy that I was able to get a working backup from it.
Do movie rental places like Blockbuster have Band of Brothers to rent?
Originally Posted by Mike8007
Originally Posted by jarvis1781
If I am wrong on this I will surely apologize, as you should for your insinuations. -
let's just say renting and DVD Backup forums don't go together
. If I wanted to know if a DVD was available for rent, I'd just call them
Jarvis may have been be a little OTT but we all get his point -
Originally Posted by Acolyte
I accept your apology for making that mistake. As for my comment it was obviously not a mistake since the poster indeed apologized for advocating piracy on this forum.
Have a nice day.
Dual band or not?
By yamatosoul in forum Video Streaming DownloadingReplies: 3Last Post: 30th Nov 2009, 17:35 -
Green Band Problem
By fusion99 in forum Blu-ray RippingReplies: 4Last Post: 6th Aug 2009, 11:58 -
green band after using restream
By thecrock in forum Newbie / General discussionsReplies: 0Last Post: 15th Dec 2008, 14:37 -
What tool can back up the “Blood Brothers”?
By coody in forum DVD RippingReplies: 2Last Post: 9th Jul 2008, 11:46 -
Smash Brothers Brawl
By seven_deuce offsuit in forum Off topicReplies: 0Last Post: 14th Mar 2008, 21:14
