My burner is a Toshiba SD-R5002 (DVD-R). It burns at 2X max but I've always heard that the slower you burn the better, so I've always burned at 1X using Ritek G03 1X DVD-R media. My question, OTHER than the write speed, is there any other differences bewteen the Ritek 1X and 4X media? In other words, if I were to continue to burn at 1X, would I gain anything by switching to their G04 4X media? Are there any other overall quality differences?
Except that most x1 and x2 drives won't burn x4 media. Most disc manufacturers will warn you of this whenever you purchase x4 discs.
I think you will find most will, BUT not at 4x, obviously. If you have a 2x writer that is all you will get out of it, firmware allowing of course.
Some drives, most noticeably the Pioneer's upto and including the 05 IIRC, need a firmware update in order to avoid possible damage to the drive before using 4x media. I occasionally use 4x media in my 2x A04 without problems. -
I have a Pioneer A03 (yes it is old) and with the firmware update I can write at 2x on the Ritek G04's with out a problem. I have over 100 burns doing this and have not had one coster. Very stable meida. So don't hesitate to burn at more than 1x.
RITEK G04's have a 1x, 2x, and 4x write strategy. You can burn them at 1x.
However, some 1x drives don't recognize them (it's a firmware issue), so they use a default write strategy. I guess it depends on your drive.
2x should have zero issues, since RITEK G03's have been around awhile.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Could be interesting for older slower burners as i have heard that 1X dvd's are no longer being produced...Originally Posted by energy80s
I guess a firmware update would cure this if the manufacture's saw fit to release one...From a newsletter from UKDVDR Suppliers
Could Be The Last 1x DVD-R We Sell As They Are No Longer Made !!
Not bothered by small problems...
Spend a night alone with a mosquito -
I have Princo 4X DVD-R's that will only burn at 1x on my Toshiba SD-R5002. I had to update the firmware to even get the drive to recognize them as blank dvd-r's (recognized it as a CD-R before firmware update), but I can still only get the drive to burn them at 1x. Anybody know of a newer/better firmware for this drive?
TOSHIBA DVD-ROM SD-R5002 [FW X033]
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 14:20 -
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 07:52 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 18:58 -
Problem Burning RW Media on SH202J
By builder in forum DVD & Blu-ray WritersReplies: 5Last Post: 6th May 2008, 11:38 -
Memorex DVD-DL "RITEK S04" PLEASE UPDATE the media section.
By Crazyj32 in forum MediaReplies: 12Last Post: 13th Nov 2007, 03:28
