Can any body tell me how to convert a VHS tape to a DVD.
Simplest thing to do is to get a standalone dvd recorder and hook it up to your vcr. It's also the most expensive. The next easiest is to get a Canopus AVDC and dump it into your computer as avi files. Then use authoring software to convert your avi files to dvd compliant files. This second method can remove macrovision protection. For more info, check the guide here and on doom9. Nyah Levi
well, you have made it to the correct site to answer your question. The next step is to look over on the left under all of the guides for some self help. After that, you can use the search function and read some posts that talk about what you want to do.
to get you started and to narrow your search, answer this question: do you want this to be a hobby or do you just want to get it done. If its a hobby, look at capturing using various capture cards. If you just want to get it done, use a hardware dvd recorder.
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 02:56 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 02:16
