Using TMPGEnc DVD Author to write .vob files then burning those files with Nero. Everything went fine and the video looks great, but I now see that I'm loosing part of the subtitles due to the fact that the video is bigger than my television screene. Any idea what I'm doing wrong? Or a sugestion for a better way to encode and write?
What was the source? Were the subtitles all on the screen in the original?
>The video files were avi and looked fine when viewed with BSPlayer.
I've had files that look one way with Windows Media Player but lose some video on the edges when viewed on TV due to overscan. If you can't watch the source on an actual TV (not computer monitor) then I don't know how you can really be sure if the problem is with the original file- but that's what I'd suspect. -
Well I'm trying to encode them again and this time I used a guid instead of my memory. One thing I forgot to do was check off "keep aspect ratio". Hopefully this will work.
OVERSCAN
Newbie Video Quality Question
By tabutcher in forum Newbie / General discussionsReplies: 3Last Post: 24th Jan 2011, 22:48 -
very newbie question about converting video.
By br9541 in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2010, 23:34 -
newbie question in dv video decoder
By pcuser82 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 14th Mar 2010, 23:42 -
Newbie question about bluray video
By Vuxius in forum Newbie / General discussionsReplies: 3Last Post: 18th Feb 2010, 17:59 -
Newbie question on video stutter . . .
By wyldberi in forum Newbie / General discussionsReplies: 12Last Post: 3rd Feb 2009, 18:14
