  1. Hi, there, I wonder if anyone can help me on this issue:
    Pentium 4 2.4 MHz
    20+130 Gb hardrive
    GeForce 4
    1 Gb RAM
    I just bought a DVD RW thingie for my computer.
    Some would say "Oh, no, E., a CD burner is more than enough for you."
    But having survived years of burning entire CD sets for a mere album (where I could get up to 48-50 files of 30 megs each), I decided that no thanks. I īve had enough of that.
    Stack ALL them files into a single DVD and I donīt have to put another thought onto it.
    Plus I can do backups of my hardrives that wonīt completelly fill my shelves.
    Said. Done.
    My first experiment, I decided to do a backup of my hardrive,.
    I have this folder CRAMMED with gigs upon gigs of images, jpegs, gifs, small CG clips, film trailers, PDFs and etc that I downloaded over the years from the internet.
    Funny stuff, cute stuff, weirds stuff, you name it, itīs there.
    I decide I wanted to do a backup of said folder since there are things there that I find priceless (and probably impossible to find again).
    I put a virgin DVD into the DVD RW tray and Sonic RecordNow DX starts.
    I select the folder (3 gigs) and start doing a backup.
    Suddenly, I receive an error message, something along the lines of :
    "The files XYZ are not original"
    OF COURSE theyīre not original.
    Nothing in that folder is!
    Or does it thinks I am the true author of the Matrix Revolutions trailer?
    It interrupts the recording and upon checking the DVD, I find out that it only recorded a couple of jpegs.
    Worst yet, I canīt stick it inside a the DVD RW and try again.
    A perfectly brand new empty DVD (3 euros) to the trash bin.
    Following this mishap, I bought Nero 6 (my Nero 5 didnīt recognise this new DVD RW thingie) only to find out that I canīt burn DVDs with it, only CDs.
    Colour me doofus, thereīs more money to the gutter..
    Can anybody help me?
    Please?
    "They say that if you play the Windows CD backward you can hear satanic speech; well, thatīs nothing.
    When you play it forward, it installs windows."
    Jan 2004
    Dallas, TX, USA
    Well I have never tried Record Now in any of the available versions so I do not have an answer for that issue. I can tell you with certainty that DVD burning IS supported with the Nero 6 that you bought. I would recommend that you upgrade it (free from Nero site) to version 6.3.0.2 due to known DVD burning issues with earlier versions.
  3. Thank you for the repply, Maestro.
    I only use Recordnow because it came with my DVD burner, Iīm more of a fan of Nero myself.
    Been using it since version 3 but I have to confess Iīve never explored all of its potential as I only use it to burn image files and the occasional monthly backup cds.
    I have this neat-looking Nero5 english-deutsch-french-italian-spanish red book but I have to confess I never really gave it a read since the mere sight gets me exhausted (manuals do this to me, I have stacks upon stacks of unread TV, VCR, etvc etc instructions manuals lying about).
    Too bad since a quick read would have saved me a lot of white hairs. :P
