Hello all, I noticed the post about PS2 and VCD, I was wondering whether it was the same deal for UK PS2's and SVCDs? Can they be played on a PS2? Or is there a disc that needs to be used, like the region free disc?
Does PS2s even support SVCDs? I'm pretty sure they support VCDs, but Super VCDs?
I have done some searching on the net and it would appear that the PS2 will play mpg2 video files, but they need a little bit of treatment first!
Firstly, use tmpgenc to create a video only mpg2 file, there is a template on the net called pss.mcf, I can't find it at the moment, goddammit!
You then need a wav file as well, which you would produce via DVD2AVI, you put both files into a PS2 video multiplexer, and it muxes them to a pss file format that can then be burnt to CDR and then played in a PS2!! -
I had one friend who did this, and it didnt work..the other did it..and it only play for 5-10 mins then crapped out...so as far as the U.S. version of PS2s go..then the answer is NO
I will be using a UK PS2 anyway 'cos I live in the UK.
I don't mind having a fiddle with the mpg2 muxing, I have most of my video that isn't DVD in mpg2 format anyway, so I don't have to do much to it to get it to work.
Can either of your friends send me a copy of the pss.mcf file that is needed?
Using my UK PS2 in the US
By ob7777777 in forum Newbie / General discussionsReplies: 1Last Post: 13th Mar 2010, 23:36 -
Ulead VideoStudio 7 Capture VHS for PC / SVCD or DVD playback
By JonnyAlpha in forum Capturing and VCRReplies: 0Last Post: 15th Feb 2010, 15:46 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 07:25 -
SVCD: Picture is not completely displayed during playback
By czerro in forum Authoring (VCD/SVCD)Replies: 5Last Post: 5th Nov 2007, 14:53 -
SVCD converted movie with choppy playback at the end on stand-alone player
By supernano in forum Video ConversionReplies: 0Last Post: 27th Oct 2007, 11:10
