I ripped and made them region 0 (or so I thought). Has anyone seen this before?
Thanks,
Brian
Results 1 to 10 of 10
Yup. It's called "your tv and/or dvd player don't play PAL discs".
Region coding has NOTHING to do with PAL/NTSC.
- Gurm -
You could purchase a good encoder like Mediaconcepts, and re-encode the program from PAL to NTSC, or go for the least hassle and get yourself a good cheap region free DVD player. You're call.
you could buy a cheap dvd player that will crap out on you in a few months or you could go to walmart & buy the pioneer dv-260. less than $80, plays pal & ntsc s/vcd & dvd-rw/+rw.. awesome dvd player.
Only problem with Pioneers (I own a DV-525) is threefold:
1. Their VCD decoding sucks. Not SVCD... just VCD. For whatever reason, their MPEG1 algorithms are just crap.
2. Seeking through a VCD or SVCD is an exercise in PAIN on a Pioneer.
3. No SVCD-DVD support.
- Gurm -
Some good guides are here: https://www.videohelp.com/guides?tools=&madeby=&formatconversionselect=&osselect=&howtos...or+List+Guides
My sub $50 US players both convert NTSC/PAL on the fly, and do it very well. It's a hell of lot simpler to do it at the player instead of re-encoding everything. (dam pesky 23.97/25 fps issues :P )
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Originally Posted by Gurm
not with the dv-260.. it would be the perfect dvd player if it could be region/macro hacked.. the vcd/mpeg1 decoding is great (svcd too), and scanning through them (using the remote) is great.. doing it on the dvd player itself is a pain..
i havent tried and svcd-dvd yet, but i believe i will..
the dv-250 is a good one too, the only real problem i have with it is the fact that it wont convert pal dvd's to ntsc on the fly.. but the dv-260 does -
Cool, I might have my next upgrade then. I hate getting rid of the DV-525, even though it's dying slowly. It plays damn near every format (except SVCD-DVD, of course).
- Gurm
Converting DVDs from Region 1 (NTSC) to Region 2 (PAL)
By Astronautilus in forum Authoring (DVD)Replies: 8Last Post: 10th Feb 2012, 04:35 -
Best region free PAL DVD player for $50 - $70
By jamest in forum DVD & Blu-ray PlayersReplies: 9Last Post: 26th Jun 2009, 04:53 -
I want to watch PAL formatted, Region 2 DVDs in the USA.
By Lori in forum DVD & Blu-ray PlayersReplies: 18Last Post: 10th Jul 2008, 19:39 -
Can't play PAL dvds on my region free player anymore
By bubblefaerie in forum DVD & Blu-ray PlayersReplies: 4Last Post: 12th May 2008, 09:51 -
Converting Region 4 (PAL?) dvds to NTSC (USA)???
By denise8593 in forum Newbie / General discussionsReplies: 9Last Post: 16th Dec 2007, 07:09
