when using tmpgenc which encoding should i use. all the avi movies i have tell me they are 14.5 frame per second or 20 frames per second but in the help guide it only list a couple but they are all much higher than mine(unless i am looking at the wrong numbers for the fps? my dvd player says it will not play pal encodings please help!!!![]()
Think your looking at the wrong number m8...
I believe PAL is at 25 FPS.
TmpgENC should pick the right one if you use your templates (dont forget those)
Hope this helps..
