  1. Hey guys!
    I have an xvid file (avi) and i would like to know how i can add a subtitle to it? It doesn't have to be selectable, just that you always see it.
    I encode my avi file with TMPGEnc, and after that i extract the ac3 sound from the avi file, because TMPGEnc does not support this. Then i add the sound to the mpg in TMPGEnc DVD Author (these are the progs i would like to keep using, because i really like them).
    Perhaps i can just add the srt-subtitle to my avi file??
    Then everything would stay the same, and i would be VERY happy.
    Thanks a lot for your time guys!
    Mad Clown...
    Apr 2002
    The State of Frustration
    Click here. You will need Virtual Dub mod, though.
    Hello.
