Hi guys,
I'm getting Cyclic Redundancy Checks on 2 out of 4 Datasafe Media 9.4GB DVD-RAM discs I recently bought.
Wondered if anyone else has experience of this media or the LG writer?
The discs were formatted as FAT32 on Win XP.
Regards
M
Results 1 to 9 of 9
i use DVDRAM on my stand alone panny E50 and i want to know how to convert the DVDRAM file to VIDEO_TS. I am running on win98 and have a lite-on dvd rom drive capable of reading DVDRAM. I know that i can do a straight copy to DVDR but the DVDR will only play on pc using power dvd xp, but i want to be able to play back my transfers on my standalone dvd player(s)
regards
Malcswhat comes around goes around -
I have so far only used Fuji ram media with no probem with the 4040b, but I don't have any experience with Datasafe Media. Do you have the latest firmware for the drive?Originally Posted by Mus1
Thanks jr,
Yes I have the latest - 3.01 as I recall. The 4.7GB Maxell that came with the 4040 seems fine but then again so is one of the Datasafe discs.
This DVD media stuff all seems a bit hit and miss to me.
PITA
M -
sorted my probs out now folks, i just upgraded to Windows XP and i can now drag the VF files to my hard drive or direct thru tmpeg dvd author
cheers
To return to my thread:
Actually I discovered yesterday there is a 302 firmware update but it has made no difference to my Datasafe media problem. Perhaps I'm best paying the money and sticking to Maxell or Panasonic like the manual recommends.
M -
Mus1,
I've used Fuji(+/-), Veratim DataLife (not plus)(+/-), Apple(-R), Ritek(+) and Phillips(+/-) with no problem all on the 301 firmware. This drive can be picky about media but you don't have to spend a fortune to get a good burn.
Thanks jr,
The DVD-RAM is of initial concern - I see Taiyo Yuden are recommended for +R in the manual so I'll check out UK prices on those and the ones you've mentioned also.
Cheers!
8)
Future of DVD-RAM?
By JamesGT in forum MediaReplies: 25Last Post: 28th Sep 2015, 19:23 -
DVD-RAM to AVI.
By aliciac in forum Video ConversionReplies: 16Last Post: 1st Apr 2011, 14:29 -
DVD Ram Drive
By gemma-the-husky in forum DVD RippingReplies: 5Last Post: 26th May 2008, 18:49 -
dvd recorder with dvd-ram, no hdd, gemstar tv guide, atsc or ntsc tuner.
By 84transam in forum DVD & Blu-ray RecordersReplies: 4Last Post: 5th Nov 2007, 19:55 -
What's wrong with this DVD-RAM?
By Shengton in forum DVD & Blu-ray WritersReplies: 2Last Post: 30th Sep 2007, 09:27
