I downloaded some concerts that I want on dvd. They play fine with the audio all synced up. But when I burn them on to dvd with ShowBiz DVD, the audio gets off at a rate of about 1 second per hour. So its starts out fine and it slowly gets off. Is there a simple way to fix this?
The only way to fix these type of avi or mpg encode errors is to stretch or shrink the length of time of the audio track using your sound editor.You have to calculate the amount of delay in the audio to video near the end of the clip and either add or subtract the time.This method wont work if there are a few bad frames that cause the audio to get delayed a few seconds.
thanks...where will i find a sound editor? Actually I don't think that is the problem, you see...it is totally fine before it gets transcoded by ShowBiz DVD. I think it is a broblem with that.
Play back stops and starts but audio is fine
By muay in forum Video ConversionReplies: 2Last Post: 22nd Apr 2011, 13:46 -
I pop in my dvd's, it starts to play, the video/audio lags
By rko2164 in forum ComputerReplies: 5Last Post: 11th Jan 2010, 21:53 -
Sync audio starts-ok but near end 1 sec lag H.264/MPEG-4 AVC AAC LC
By JoeBolden in forum Video ConversionReplies: 6Last Post: 7th Jan 2010, 15:31 -
Video is out of sync (audio is fine)
By MaxNH in forum Newbie / General discussionsReplies: 4Last Post: 29th Dec 2009, 11:55 -
DVD playback fine on computers, but not so fine on home players...
By stonesfan in forum Authoring (DVD)Replies: 2Last Post: 15th Nov 2009, 18:03
