I'm using VirtualDub MOD to edit an m2v file, but when I go to use frameserve, it just sits at zero forever. Any idea why?
What program is it frameserving to? And what are you hoping frameserving will do?
Thanks, guys. You've answered my questions with your's. This is my first attempt at frameserving.
I'm going from VirtualDub to TMPGEnc. Trying to keep my file in m2v format, and this helps.
Thanks again. -
Right, frameserving just sets it up. When you go to TMPGEnc, you access the file that you have set up and TMPGEnc uses that file to encode. Look up frameserving with Virtualdub in the guides.
Divx/Xvid problem in Virtualdub (not mod)
By leeqk in forum Newbie / General discussionsReplies: 14Last Post: 11th Apr 2010, 02:18 -
Frameserve from virtualdub to HC
By SatStorm in forum Video ConversionReplies: 2Last Post: 12th Jun 2009, 07:24 -
problem with Dr Divx & VirtualDub Mod
By pcb in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2008, 14:59 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08 -
Is it possible to frameserve with Virtualdub to MeGui?
By salidarius in forum Video ConversionReplies: 8Last Post: 13th Feb 2008, 06:41
