I was able to buy (on Amazon Germany) a nice widescreen PAL copy of the Disney movie of a few years ago, Rocketman (in Germany it's called Spaceman, but it's the same movie) because Disney never sold the DVD in the US in NTSC. I have long sense modified my DVD player to play PAL movies, so I thought no problem. Wrong. The LBX is streatched up to full screen height. Bummer. So, I figured I would convert. I've done it before for another PAL I bought, and DVD2SVCD does the LBX conversion right; I did it for Swan Princess (again a never on DVD in the US...). But now I've got a DVD burner, so I figured I'd just convert and stay DVD. So I ran DVDDecrypter & DVD Fab. I got a DVD-R that's now NTSC... and my computer DVD player knows it's LBX, but my stand alone DVD player STILL streaches it out full height. I e-mailed DVDDecrypter (and paid a little contribution) but they haven't suggested anything yet. Any ideas (other than doing a SVCD, which I know works)?
Larry Elie
Sounds like something's going wonky with your player's autodetection of whether to do 16x9 stretch or not. Have you played with the player's settings?
- Gurm -
Yes. The easy test is to play a NTSC 16/9 movie, and see what you can or cannot do to it. They work fine. Again, the movie is fine on the computer, but the player just refuses to let it be other than full screen.
also check the ifo file that was made for the disc. Perhaps its giving wrong info about the movie (that can sometimes screw up the letterboxing on machines ex saying a film is 4:3 when it should be 16x9 letterboxed)-- and in one case i had that was the problem
first you need an app called ifoedit (it is in the tools section on this site). then using ifo edit, you would open up the "video_ts.ifo file" this is located in the video_ts folder on your dvd (or dvd folder if you still got it on your hard drive). It will show you how many play items you have. In your case if you have just the film, it would say 1 title set, and it i will give you all of the info about it. If you see the info is wrong, double click it and it will let
you correct it. then just save.. Next you would have to open up the ifo file for whatever title the actual fim is and do the samething there -
their are quite a number of how to guides and psot about that topic on this site. Check out the guides section or do some searches in the forums, and you will get a lot fo results
DVD PAL to NTSC or NTSC to PAL DVD Conversion
By Baldrick in forum DVD RippingReplies: 21Last Post: 12th Apr 2016, 17:30 -
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
4:3 LBX DVD to Divx cropping question
By ecc in forum Video ConversionReplies: 3Last Post: 1st Oct 2008, 12:11
