Hi,
I tried using this app on some .vob files with subs but am unable to extract the .sub files
When I use the binary only I get error when choosing the .png format (which should be the default format in SUBtractor) and strange outlined letters and background when using the default .bmp format.
Any idea to get SUBtractor to work with Sizzle?
Thanks!
Yoko
P.S. I don't have Fink installed so in case I should need libpng someone should give me an idea how to compile![]()
when i use the vob2sub binary inside SUBtractor I can rip subs but only in bmp format; when I use SUBtractor I don't get any SUB, that's my problem.Originally Posted by qshartle
cheers
y. -
odd.
Rerip it with DVD extractor, or Yade in OS 9.
Then try it.
Q"Good Luck 007"
In Memory of Desmond Llewelyn -
any other suggestion than re-ripping with an OS i don't have installed?Originally Posted by qshartle
Where can SUBtractor be downloaded? http://thegoods.ath.cx/~hmason/subtractor/ is not working.
Is it discontinued?
/Rob
