I tried to use GPRMs registers to control various things in Scenarist but it won't work.
For example, I tried to highlight button in my chapter menu regarding last played chapter (If user hit MENU during playback to go to chapter menu, I wanted to highlight buton that correspond to current chapter from which user pressed menu button).
By setting GPRM0 register to some value during playback (after cell played) and setting highlight button value to GPRM0 before menu is opened - nothing happened - fisrt button was highlighted instead one I wanted...
I also tried simple setting GPRM0 to some value and as a next command seting highlight button to GPRM0 but still no change...
What am I doing wrong in using GPRMs ?
just one question where did you get hold of that program?
i Want to go a DVD authoring edjucation. Can you do that? -
yeah i would also like to find out more on how to use the GPRMs on SCENARIST! can anyone enlighten me or send me links to anywhere i can find out more?Originally Posted by arminio
the main prob i have is this:
for motion menu, for eg. i have several buttons namely 1-6 for eg. then i navigate to, lets say button 3... then the menu finish the loop. i wan the highlight to stay at dat button when the loop starts again instead of jumping back to the first button. anyhelp here?
n don't tell me to lengthen the menu.... cos i am currently doing a digital magazine... so sometimes the loop is not long enough for slow reader to finish reading... n so instead of having the viewer re-navigate again...(and also to hide the loop) can i set anything to let the highlight stay even when loop restart??
thanks! need help fast.... my boss is breathing down my neck...
The manual has a pretty good tutorial on using the registers.
And you have to use command sequences to do this.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
May he had $26,000 to spareNo DVD can withstand the power of DVDShrink along with AnyDVD! -
Check www.sonic.com for a dealer in your area.Originally Posted by jtoolman2000ICBM target coordinates:
and how do i use the command sequence.... somehow i cant get it to work for me....Originally Posted by SLK001
Scenarist Mux Server Problem...Anyone?
By Thommers in forum Authoring (Blu-ray)Replies: 4Last Post: 11th Jun 2009, 14:06 -
Scenarist 4.3 subtitles problem
By paulspurrier in forum Authoring (Blu-ray)Replies: 1Last Post: 11th Jun 2009, 07:16 -
Has anyone used Sonic Scenarist or DVDit pro HD?
By jbandy1 in forum Authoring (Blu-ray)Replies: 16Last Post: 18th Feb 2009, 02:08 -
error when import subtitle in scenarist
By pcb in forum SubtitleReplies: 4Last Post: 17th Feb 2009, 06:38 -
Scenarist Menus
By nx01rules in forum Authoring (DVD)Replies: 5Last Post: 11th Nov 2008, 01:22
