I recently got a Sony 510a and the wrong software came with it. Called the Co and they sent a disk that had the correct software - but it was a burnt cdr!
Yes, I have a call into the company (Pc hardware 4u) to get an oem disk, not a copy. But just in case the problem is not the disk, and is a real problem encounter by others, here is my problem.
I installed mydvd, rebooted and got as far in the reboot to a blue screen and - an exception oe has occurred.... in vxd... Th computer hung there so I rebooted in safe mode and uninstalled mydvd and all was well.
I tried a variety of fixes, some from the web (move files from common files to mydvd folder) and some on my own but not luck.
I did use Uleads Movie Factory (the software that came with the drive, but the wrong software) to capture and burn a dvd and it worked fine, but I bought the drive both for the drive and the software, especially Veritis backup software since I have backup exec.
My system is win 98se, Sony dru510a (European version), 1.2 gig athlon and 2 large capacity drives.
Sorry!
Has anyone had this problem - my dvd causing a hanup when booting?
If so, what can be done to correct it? -
billbath,
I had a similar problem on a win98 machine.
Upgraded to WIN XP
No more problems.
How long does it take for your computer to boot up to desktop?
By johns0 in forum PollsReplies: 21Last Post: 31st Jul 2011, 12:19 -
Computer would not boot anymore
By videohalp in forum ComputerReplies: 17Last Post: 26th Jul 2009, 03:25 -
Computer Boot Errors
By joeyjoejnr in forum ComputerReplies: 1Last Post: 7th Apr 2009, 13:42 -
Computer will power on but not boot
By surger1 in forum ComputerReplies: 18Last Post: 20th May 2007, 17:21 -
computer powers on, will not boot
By Dr_Layne in forum ComputerReplies: 9Last Post: 12th May 2007, 00:51
