ok i have the vobs and ifo off the dvd swat but not the disc anymore how can i compress or shrink these to get them to a dvd+r disc
thank you
Results 1 to 12 of 12
Ted Rossin
http://www.tedrossin.0sites.net/ -
ok i used dvd shrink but when i select the ifo it says cannot find the file specified??? like it cant open it or somthing
I use RecordNow Max. The result of running dvdshrink is a directory named VIDEO_TS with new VOBs and IFOs. You will need to create an empty AUDIO_TS directory at the same level as the VIDEO_TS directory and put these two directories onto your DVD. Most DVD recorders come with code to record to the disk. If you don't have code to burn a DVD, I hear the DVDDecrypter can do the job as well. I'm sure you can find a guide at this site to explain the entire process.
Ted Rossin
well see thats the prob when i select the ifo when dvd shrink it just says cannot open the file specified because it can t find it or somthing??
I'd say that your problem is that you ripped in IFO mode. You should've ripped in File Mode and get all the files. I'm betting that you are missing valuable files like VIDEO_TS.* and VTS_*_0.VOBs. Can you provide exactly what files you have? As this is much needed important information.Originally Posted by hatchetman420
If you can't get your original DVD back, you may have to settle for a movie only backup using DVD Shrink's re-authoring. -
i think i have the movie only not the extras
so how do i re author to burn the movie only? -
ok is there anyother way then dvd shrink it is not working for me
i have 5 vob files one info.txt and one ifo -
Your IFO should be the same # as your VOB. e.g.Originally Posted by hatchetman420
VTS_01_0.IFO
VTS_01_1.VOB
VTS_01_2.VOB
VTS_01_3.VOB
VTS_01_4.VOB
Open VTS_01_0.IFO with DVD Shrink. Click on reauthor button and drag your movie title into DVD compilation area. Dragging technique will differ on what version you are using so use the approriate guide for it.
Trim VOBs to re-burn to DVD
By ehmjay in forum MacReplies: 7Last Post: 16th Nov 2008, 17:59 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 11:52 -
Create DVD from several VOBs ?
By flash70 in forum DVD RippingReplies: 3Last Post: 8th Jun 2008, 10:51 -
Missing vobs on DVD
By stencil in forum Newbie / General discussionsReplies: 4Last Post: 13th May 2008, 00:17 -
How to Fit five VOBs onto one DVD?
By DeEp34 in forum Newbie / General discussionsReplies: 10Last Post: 14th Jul 2007, 20:42
