after you have done a motion render in dvd lab and has encoded it in tempgnc or something, after you have done that the audio that you have put there doesn't play.
it plays if you just add a video as a motion menu directly into the menu but don't edit it in render motion menu.
anyone skilled in dvd lab who knows the answer?
hm Maybe you must use multiple audios?)
i Want to go a DVD authoring edjucation. Can you do that?
The rendered video is just video, so you will probably have to drag the audio asset back to the menu after you place the newly encoded video on the menu.
just a guess on my part, 'cause I have not had this issue before in either version 1.3 or 1.4 -
Originally Posted by andkiichi Want to go a DVD authoring edjucation. Can you do that?
DVD Lab Pro 2's Render Menu Motion - Intro and Loop Questions?
By xhonzi in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2009, 17:52 -
Vegas to DVD Lab Pro motion menu issues
By outerspacerace in forum Authoring (DVD)Replies: 4Last Post: 23rd Jun 2008, 20:28 -
One Cell Motion Render in DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 0Last Post: 23rd May 2008, 09:07 -
Motion Menu on dvd lab pro 2
By djakaburo in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2008, 12:03 -
how to make motion menu in dvd-lab pro that like this
By 741210 in forum Authoring (DVD)Replies: 10Last Post: 23rd Aug 2007, 22:53
