Im trying to convert a wmv ...what does "Cant load "P3Package.dll" means. I cant get it to convert.help please.
Mermaid
Mermaid, don't think I'm jumping on you. This is just a pet peeve of mine. Wouldn't "What does "Cant load "P3Package.dll" mean?" be a better subject line than "Help Me"?
The whole idea of subject lines is to make it easier for people to find threads that are relevent to them or that they feel they can be helpful with. -
to add to presto's comment, it also makes it easier to do a search for someone else that is having the same problems.
Let's pretend that this thread was made by someone else and they did what you did. Then you come along and do a search (btw, did you?). You type in "P3Package.dll" or something else to try to see what others have done to fix this issue. You are then hit with about 5 pages of "help", "help me", "newbie Q". etc.
Most people (and I try to do the same) ignore threads with the subject line's like this one. Anyway, baldrick's link should answer your question (guessing he used the search function).
