Hello,
Is there any difference between divx and avi.I've files with avi extension and play them with a divx player.Now, I'd like to burn these avi files on a standard cd and would like to play them on a dvd player which supports the divx format.
How shld i burn them into a cd using nero-6??Is it just by choosing standard cd-rom mode??
Thanks for your time
Just bacuse they will play on divx player (software) doesn't mean they are divx files!
AFAIK, divx player (software) will play any avi file you have the codec installed for.
Open the files in GSPOT to check which codec they were made with. Otherwise you may well end up burning something your DVD/Divx player can't handle.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Can't convert avi to an avi that the my divx player will read.
By aarelovich in forum Video ConversionReplies: 5Last Post: 4th Feb 2010, 06:19 -
divx to avi with divx author
By pred in forum Video ConversionReplies: 4Last Post: 12th Nov 2008, 23:32 -
avi to DivX using divX converter pro
By Deaf Raiders in forum Video ConversionReplies: 3Last Post: 19th Dec 2007, 13:28 -
Convert this avi to DivX avi (GSpot Screenshot included)
By indiannawaf in forum Newbie / General discussionsReplies: 13Last Post: 22nd Aug 2007, 11:26
