I have recently been experiencing problems with my DVD-RW Drive,
Problem No. 1: sometimes when I try to write a cd am I told that there I an error with the disk and i needs to be replaced so i replace it and it does the same again
Problem No. 2: the cd writing process is completed and when the cd is played in a cd player the cd plays as if it was severely scratched
Problem No. 3: if i try to write a data cd (photos, guitar tabs etc) it won't write giving the same problem as number 1,
This is becoming very annoying and also expensive due to cds being wasted.
is there anything that could be done to fix these problems?
One of the best pieces of advice I got from these forums is to simply clean the lens...I was having problems with DVD-RWs appearing not to be re-writable and it all cleared up when I cleaned the lens. Worth a try, I guess...
The future is much like the present, only longer.
DVD exploding inside the drive from a drive exceeding 24x. True?
By snafubaby in forum MediaReplies: 10Last Post: 5th Dec 2010, 19:05 -
DVD skipping problem. Slow drive speed.
By rayden54 in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Jan 2010, 16:37 -
Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
By vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 19:38 -
problem with my cd/dvd-rw drive or with nero or both!
By NBABE1 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Sep 2008, 14:20 -
problem burning with external dvd drive
By billybob59 in forum DVD & Blu-ray WritersReplies: 15Last Post: 8th Mar 2008, 20:32
