Is there any program that can use add 2 second black frame to the end of a MPEG2 file without recode?
I got some ready-to-burn SVCD MPEG2 file that were play perfectly but once I burn them into CD, they were all shorten about 1-2 second. Making it very annoy to watch.![]()
So I'm thinking to add couple of seconds black frame at the end of the files. Hoping it will work.![]()
Thanks!
Just try, it work but the problem remain.
Here's how I create the file:
-Captured 3 TV programs by TV card all in MJPEG-PCM avi files.
-Using Nandub crop out Ad etc., becomes about 20min each. (Since I want to put all 3 programs into one SVCD, so I cropped very "accurately sharp".)
-Using TMPGEnc Wizard convert them to SVCD 2Pass VBR@500/1500/2520 Joint-Stereo 224kbps.
Up to this point the files still play from start to end correctly and perfectly.
-Then create bin/cue by VCDEasy, SVCD 1.0.
-Burn to disc by Nero.
The SVCD created play smooth in DVD player but at the end of each chapter (3 chapters total) it finished about half second earier than it should be, sound and video both.
Even I merge 2 seconds black frame to it the problem still remain.
Is that relate how I cut out the Ad? But it play right.
Any clue? -
Originally Posted by thomasm
Dunno really, just thinking of things to try.
how to insert an i-frame in AVIDEMUX2
By shparekh in forum Video ConversionReplies: 5Last Post: 24th Aug 2011, 06:39 -
A way to insert black in frames' center and vertically push apart video?
By sincostan45 in forum EditingReplies: 5Last Post: 10th Jun 2011, 17:40 -
how do i insert a title frame (e.g. a mpeg, bmp or gif)
By eduardo0701 in forum Newbie / General discussionsReplies: 3Last Post: 20th Jul 2010, 09:20 -
How do I insert an image into the middle of a video (freeze frame effect)?
By maskingtape in forum Newbie / General discussionsReplies: 1Last Post: 9th Jul 2010, 23:40 -
Any way to insert 1 frame image at the beginning of an mp4 (using AutoGK)
By cryptyk in forum DVD RippingReplies: 11Last Post: 10th Sep 2008, 22:03
