I can't print onto my printable DVD-R using the damn plastic peice that came with my EPSON 900 they are always either way off on the other side or print like in the middle of the dvd-r or on the upper left side but never right on the DVD itself. I have tryed nero and coverXP Pro and neither work can anyone give me some advise or help on the software or something its pissing me off wasting all this ink and my plastic peice is covered in ink now![]()
I always use the software that came with my epson r300 "epson print cd"
i believe the 960's come with it to. have you tried that? I also bought a cheap pack of printable cdrs to practice printing when i first bought it so i would know what works best. -
Use the epson print cd software which is supplied with the printer...
Its easy to use and does what its supposed to do....
Put the picture in the right place on the caddy...Not bothered by small problems...
Spend a night alone with a mosquito -
Sweet thx i just found the software cd i lost it and wasnt sure if i was gonna find it or not and yea i've been using like 1X printable princo's i got for like 15cents/each off ebay
i would never use my riteks without first checking.
Does size really matter?
By ingeborgdot in forum ComputerReplies: 21Last Post: 25th Jun 2011, 11:11 -
So is any DV codec better than MainConcept at decoding? Does it matter?
By Asterra in forum Video ConversionReplies: 11Last Post: 20th May 2011, 23:59 -
"Capturing" DV footage - does software matter?
By spup345 in forum Capturing and VCRReplies: 4Last Post: 19th Jan 2010, 20:43 -
Why does the disc speed matter with the burning?
By coody in forum DVD RippingReplies: 20Last Post: 31st Jan 2008, 19:39 -
Transfer miniDV to hard drive. Does it matter what software is used?
By vid83 in forum Newbie / General discussionsReplies: 9Last Post: 11th Dec 2007, 20:08
