I just visited Cyberhome.com and found that they are now offering a download which will fix the problem of being unable to edit the title on DVD+R disks.
Personally, I have the model 2500. Should I try the fix on MY unit?
Here's the download page:
http://www.cyberhome.com/downloads.asp?Product=1500
The Martian
I thought that 2500 is same as 1500 only in black. Am I wrong ? Try to contact their support.
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
I, too, thought the 2500 was the same as the 1500 except for the color. The firmware download for the 1500 has two versions, depending on the type of tuner ("X" or "P"). I downloaded the "X" version, but don't know whether I should risk using it with my 2500. I wonder if it could do some harm if it's not compatible.
Customer support is nowhere to be found.
The Martian
Thanks a ton for this link. I just upgraded mine and I'm about to give it the test. Version info looks right...wish me luck.
Are there any more firmware upgrades for this machine at this time?
-Homsar -
You're welcome. I hope you have the same success as I. I followed the procedure on the Cyberhome website and upgraded my firmware earlier today. Initial tests showed that everything is working fine, and I can now edit titles on +R disks. I feel much better about owning this unit now.
The Martian
trying to edit dvd get VTS_18_0.IFO contains bogus data error, FIX?
By Denvers Dawgs in forum Authoring (DVD)Replies: 6Last Post: 2nd Apr 2011, 17:45 -
How to fix/edit a damaged video iso?
By hibbs in forum Newbie / General discussionsReplies: 8Last Post: 20th Jul 2010, 17:24 -
How can I fix the playback time of a title when replace the VOB?
By Massa in forum Authoring (DVD)Replies: 5Last Post: 17th Jan 2009, 14:25 -
Help me get rid of/edit out title slide in photo video (.mpg)
By FuGGer in forum EditingReplies: 3Last Post: 15th Jan 2009, 19:39 -
New Tool SetMismatchSUB : Fix , Mix , Edit , Join .SUB file(s)
By Goldenaxe4000 in forum SubtitleReplies: 0Last Post: 1st Aug 2007, 13:05
