I've searched the forum for the answer and it appears that there isn't one. There is even mention of DTS being "hack-proof". Is this true? Is there truly no way to losslessly capture a DTS track from a DVD and convert it to WAV without re-recording it?
I'm curious because I have a DVD with a DTS track. The DTS track is the *only* one available. There is another PCM stream there for DVD format compliance, but it's completely silent.
Thanks.
Don't know the answer to your question, although I'd like too, but I found this with a Google search,
http://www.google.com/search?hl=en&ie=UTF-8&oe=UTF-8&q=converting+DTS+to+.wav
Some of it points to this website and some for others. Maybe you can find a definitive answer there.
Good luck!
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25 -
delaycut - ac3/eac3/dts/mpa/wav delay+cut tool: v1.4.3.2
By amtm in forum AudioReplies: 21Last Post: 23rd Nov 2011, 08:34 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 21:24 -
convert dts 5.1 wav to ordinary mp3 etc.
By flannob in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2010, 05:02
