Here is the deal folks. I have a pinnacle Lynx2 capture card and it came with studio 8.
I started a project a while ago that required that i fit a bunch of videos on one cd. I had no problem using video's in wmv format, at 128KBps, that needed to be viewed on a reduced screen.
I cant seem to produce RM video file using my studio8 program.
An hour long video in 128KBps wmv format is about 45MB in size on my computer. What i found recently was a particular rm video of 35 mins length that was only 9.5 MB in size. Looking at the file sizes per minute I seem to think that the rm file is even more condensed then the wmv format.
Is it possible to make videos of the same quality on as my wmv 128KBps videos in the format of RM without losing video quality? In other words can i get the same quality with the reduced file size doing my videos in rm format as compared to the 128 wmv versions?
Where would i find a video converter that would do this
Thanks a million....
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 03:44 -
How to calculate the sample size of wmv Video file
By asifjavaid in forum Video ConversionReplies: 3Last Post: 13th Apr 2009, 09:33 -
H.264 output file size too big vs WMV
By bijoythulas in forum Video ConversionReplies: 5Last Post: 29th Sep 2008, 22:21 -
Why is this wmv file the wrong size?
By abisti in forum Newbie / General discussionsReplies: 8Last Post: 5th Feb 2008, 19:14
