  1. Member Sakuya's Avatar
    Dec 2002
    I was wondering. I made a CD composed of MP3s but then I went and deleted the source MP3s in my computer. Is there any way that I can get back the songs in my computer without having to re-download the songs? I know that cut and paste won't work.
    Nov 2003
    Houston, TX
    i'm not sure i understand ur question....but if u made a cd with mp3's that u don't have anymore...just drag the mp3's off the cd and onto your computer.......(or check recyclin bin)
    hope this helps, josh
  3. Originally Posted by Sakuya
    Correct BUT Copy and Paste will work.
    Rick
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Two options - You made an audio CD which would have converted the MP3s to audio tracks OR you made a data CD with MP3s on it. In the first instance all you need is a CD Ripper (CDEX is my choice) to convert back to MP3. In the second instance just copy and paste.
    If in doubt, Google it.
