I used the Morgan M-Jpeg compression codec to capture to AVI format with ATI AWI 8500DV (MMC 8.8 software) through my VCR. When I try to open the AVI file in Adobe Premiere 6.0 I get "Unable to open that file...File uses an unsupported compression format". Does Premiere not support the Morgan compression? What compression does it support? Thanks.
Live Long, Play Hard, Think BIG!
Short AVI movies from my digital camera use MJPEG also.
Windows XP could play them fine but Adobe wouldn't recognize them.
Until I installed Morgan MJPEG that is.
But since you say you already have Morgan MJPEG installed, I would guess that maybe you don't have the full comress + decompress version or you don't have your decompressor side configured correctly.
If you're using a compressor that came with your ATI or one you downloaded for free, you may need to buy the full version from Morgan.
If you have the full version, check your decompress settings and also try a re-install. You may need to install the codec AFTER installing Premiere.
At any rate Morgan MJPEG works fine for me with Adobe Premiere 6 and Windows XP. -
Thanks for the reply. I figured out my problem. I tried to "open" the avi file instead of "importing" it. When I chose import it worked fine. Thanks for the help!
Super Easy Question about COMPRESSION USING ADOBE PREMIERE PRO CS5
By BronProductions in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2012, 18:48 -
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
File format not supported on mp3 adobe premiere cs3
By afrojavi in forum EditingReplies: 2Last Post: 26th Apr 2010, 05:35 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17 -
Premiere 6.5 - unsupported compression format.
By vodmare in forum EditingReplies: 3Last Post: 28th Jan 2008, 16:51
