I have a 640x360 DivX that I would like to convert to SVCD, 480x480. I would like to keep the proper aspect ratio in the final mpeg, and not have to crop the sides. I'm guessing my mpeg should look stretched on the PC, and then get faltened out on the TV. Do I have to encode the SVCD with a special flag to tell the DVD player how to properly display the picture? Also, can I use TMPGenc to do the resize, or is there a good VirtualDub filter, such as Smart Resize?
You can resize in Tmpg as well. Play around a bit with the video arrange methods.
Probably the way to go is:
center(costom size) 640 (or 480?)x360
Video tab: res 480x480, 4:3 (NTSC)
TMPG adds the borders automaticly.
640x360 is 16:9 without any borders? Then try source aspect ratio 16:9 full screen (keep aspect ratio)
Video tab: res 480x480, 4:3 (NTSC) -
Thanks for your reply. Both of these methods crop the sides of the video. Just a bit, but it's noticable. I think you are on the right track thought. I'm going to mess with the settings for a bit.
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 03:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 13:20 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 07:25 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
