  1. I got a MPEG moive with framerate 30 fps. I wanted to burn it into DVD but 30 fps is not the standard rate for NTSC.
    I just wonder whether there are methods to convert 30 fps into 29.97 without re-encoding the moive.
    Jul 2002
    Try pulldown, in the tools section
    "The software said Win XP or better, so I Installed Linux"
  3. I use pulldown to convert 23.976 fps into 29.97. But I am not sure it can be done in the other way round (i.e. from 30 to 29.97)
  4. Use DVD patcher, patch the whole file when asked. Set the new framerate to 29.97fps.
    Audio sync may drift slightly but it shouldn't be noticeable unless it is a really long movie.
    Mar 2003
    Uranus
    3.6 seconds per hour seems more than "slightly"
    May 2001
    PULLDOWN, DVDPatcher or RESTREAM will do what you need. There is no need to re-encode.
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
  7. Originally Posted by FOO
    Hmmm, you are right. Never actually calculated it. 30.00 - 29.97 = 0.03. Just looked like a pretty small number to me
    Mar 2003
    Uranus
    That's what I thought too. Then I did it .
    My rule of thumb is anything more than 2 frames outta sync
    is too much. ~ 66 ms
    The difference is 1 part in a thousand or 1 second every 17 minutes.
    So outta sync is detectable after around 1.2 minutes
