  1. I am trying to burn a DVD that will, for instance play in a shop window all day long. It doesnt appear to be an option on my DVD player. Can you program the DVD to start up automatically on insert and play on a continuous loop until it is ejected? What is a good authoring tool for this if so. Using a PC...
    Apr 2002
    Australia
    If you can get a copy of it try DVD Maestro. I haven't tried any other 'serious' authoring software but I know that tyhis one will allow you to create a loop. I'm not sure if any mainstream (read el-cheapo) authoring software will let you do this but basically you add your movie to loop into the project and set the "Next Play" item to itself. You can specify the number of times to loop or just have it loop forever. You can also set the actions for other buttons as well so you can escape from the loop.
    "Weekends don't count unless you spend them doing something completely pointless."
    Bartman 8)
  3. Member The village idiot's Avatar
    Apr 2002
    Adrift among the STUPID
    Some players will let you set them to repeat the selected video until you stop them.
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
    Sep 2001
    If you aurthor the DVD in DVD-Lab, then it should allow you to do this as well.
    It won't really be an option to select, you would just link it together to do it.
    Tearren
