Results 1 to 15 of 15
  1. Are PC games written on cds or dvds? How do you bypass the copy protection and burn them?
  2. Member adam's Avatar
    Sep 2000
    Pc games could be written on DVDs or cds, but since not everyone has a DVD-Rom they are generally released on cd media.
    If the game is copyprotected you usually need to use a modified .exe file to load it. There are so many sites which deal specifically with backing up pc games. I would think DVDRhelp would be the last place you would look for this type of question.
  3. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    Try searching for a site called gamecopyworld.
    It may even be .com, I can't remember (the last game I played was Tomb Raider 3)
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    If in doubt, Google it.
  5. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    Are Disk Images possible on a PC?
    for me I just back up all my games to Image format and then burn them all to a DVD
    i can fit a lot of game images on DVD so thats why i do that.
    if i want to play them, i just put the dvd in, mount the image and off I go.
    Is something like this possible on PC?
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Originally Posted by galactica
    I just put the origional in one drive, a cdr in the other drive and COPY.
    It may be different for MACs, but how does this get around games that require NoCD cracks ? My point is that with PC Games often you have to apply NoCD Cracks so that the game swill run off burnt CDs. Simply copying the CD in its entirety generally doesn't work - not with any EA or Codemasters games anyway.
  7. Alcohol 120% can copy most protected CDs perfectly... If u dont want to use the CD to play, then got gamecopyworld, megagames, or just search google for the NoCD Patch to play. Make sure it matches your version tho. Astalavista.box.sk also has many game patches, but deals mostly illegal stuff.
  8. Clonecd is also another very good cd copiing program.. This should be able to get throught the cd copy protection.
  9. Member galactica's Avatar
    Jan 2003
    it must be then..............
    I have yet to find one of the games I own not work with cd to cdr copying. It seems pointless to use a NoCD crack just to use a cdr!
    how about disk images!? can PC's make those? Often i just image my cd, mount it and then it plays just like the cd was in there.
  10. u can do that on a PC, sure.
    You don't need NoCD cracks for burned CDs, do you? (I don't) What copy protection scheme requires this?
    NoCD is for playing without the CD in the drive, to save yourself from constant disc switching...
  11. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    You don't NEED them, but just a preference thing for me....
  12. another thing you can do is copy it in nero using RAW mode and it will copy perfectly and play off the cd.
    Apr 2004
    Hudson, Florida
    In my mind the only 3 tools you really need to backup PC games are Alcohol 120%, A-Ray Scanner, and a decent CD/DVD burner. I actually preffered to make CD images and use virtual drives to play my PC games, that way you don't get any lag you might get with your CD/DVD-ROM.
    Using this method all you have to do is scan your disc with A-Ray scanner, this will tell you what copy protection the disc has. Then you pick the copy protections profile in Alcohol 120% and write at the slowest speeds.
  14. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    I haven't found a NoCD crack for Doom3 yet. I looked as soon as I got it. Also, I heard Doom3 has Safedisc 3.2 - a real bitch to get around
    Apr 2004
    Hudson, Florida
    I have the no CD crack if you want it.
