I am trying to get a list of DVD+R/RW's that are compatible with this recorder. I cannot download the list on the website for the product because I have a webtv. I would also like to know where the best deals are to get these disks. Any help at all would be appreciated because I have yet to find someone to help me on this issue.
Results 1 to 11 of 11
Any RICOHJPN disc will work fine.
This is the official list from the pdf file from Cyberhome's ftp site:
Supported Blank DVD+R Discs List
DVD+R Date: 10-01-2003
Disc Label, Disc Information, TID, Writing Speed, Note:
MCC MCC 002 4X
RITEK RITEK R02 4X
CMC Magnetics Corporation CMC MAG F01 4X
RICOH (RITEK-OEM) RICOHJPN R01 4X
Taiyo Yuden Company Limited YUDEN000 T01 4X
Prodisc Technology Inc. PRODISC R02 4X
Unknown BeAll000 P40 4X
MBI MBIPG101 R03 4X
MCC MCC 001 2.4X
RITEK RITEK R01 2.4X
CMC Magnetics Corporation CMC MAG R01 2.4X
Prodisc Technology Inc. PRODISC R01 2.4X
DAXON DAXON AZ0 2.4X
RICOH (RITEK-OEM) RICOHJPN R00 2.4X
SAMAUNG BEALL P0 001 2.4X
Memorex SKYMEDIA R01 2.4X
MEDIANCA DDDessau V10 2.4X
Supported Blank DVD+RW Discs List
DVD+RW Date: 10-01-2003
MCC MKM A02 4X
RITEK RITEK 004 4X
CMC Magnetics Corporation CMC MAG W02 4X
INFODISK INFODISC A10 4X
PHILIPS PHILIPS 041 4X
DAXON DAXON D41 4X
RICOH (RITEK-OEM) RICOHJPN W11 4X
MCC MCC A01 2.4X
RITEK RITEK 001 2.4X
CMC Magnetics Corporation CMC MAG W01 2.4X
Prodisc Technology Inc. PRODISC W01 2.4X
INFODISK INFODISK A01 2.4X
RICOH (RITEK-OEM) RICOHJPN W01 2.4X
Intenso OPTODISC OP1 2.4X
I got a 25 pack of RITEK 2.4X DVD+RW from Shop4Tech for around $40 inc free shipping. Deals can be had for less than this if you keep your eye out. I have experienced no problems with the RITEK discs. A quick look at Shop4Tech's site shows they are doing the Optodisc DVD+RW 2.4X for $32.25 for 25 discs inc free shipping. -
Thank you so much for your help!! Now I have to get some credit on the card back from bad purchases and try these. Any one else that can help me find good deals on these disks would greatly be appreciated. I also had another question...does the speed of the disk determine how much you are able to store on it?
No the speed of the disc does not affect the amount you can store on it. The disc will store around 4.3GB of video regardless of the speed.
To my knowledge the speed of the disc on desktop recorders WITHOUT a HDD is irrelevant as it records in realtime. Maybe it affects the amount of time to finalize a disc or make compatible? If you have a HDD on your recorder it would affect the amount of time to dub from the HDD to a disc. -
Little off topic but media speed is important for Recorders that offer PWR (Play While Recording). You need at least 2x media for that function.Originally Posted by Mediaman2000Pinnacle Studio 8 and DV home video editing (ver.9 already home)
Any information and tips help because I have never worked any equipment like this before.Are there any other online sites to buy the compatible disks at to record on besides SHop4Tech? I am trying to find some of the disks but the only ones I find prodominantly are the RITEKs. And is the number on the descriptions given (like R02) important to find in the description to buy these disks?
Problem with media is that it says something when you buy and inside is different media. That is what that another text (f.e. RICOHJPN R01) mean. You can find with DVD Writer (one in PC) and DVDInfoPro what realy manufacturer ID is.
Another websites that I know are
http://www.allmediaoutlet.com/amo/
http://www.meritline.com/Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
INFODISC (Memorex 2.4 x DVD+RW) works well too.
Just curious of the success (or lack thereof) you have had playing the 1500's DVD+Rs in other players. (And yes, I did give them plenty of time to 'Finalize.')
I have had absolutely no luck using 4x DVD+R RITEK RICOHHJPN R01 discs branded as a Fuji spindle. The 1500 will play them all day long, but I have had no success playing them in 5 different units: a Cyberhome CH-500, CH-402, Pioneer DVD-R burner, Emprex DVD±R burner, or my Vaio laptop DVD player. The +RW discs play pretty well in most of those players, believe it or not.
I can actually copy all the +R files onto my hard drive, except one tiny ifo file which is crucial to the menu structure, apparently. It says it can't read that file.
So now, the only solution seems to be to record in +RW then copy them to + or -R on my computer. Not exactly the hassle-free process I had in mind.
The Ritek media I used is on Cyberhome's list of 'supported blank DVD+R discs.' I used DVDinfoPro to determine the exact media type, and highly recommend its use prior to engaging in media type discussion. http://www.dvdinfopro.com/
I figured that if mine was a widespread problem I would have heard a lot more complaints about it, but there are few. Surely I'm not the only one who has had this problem, though.
What +R media types have you had success playing on a wide variety of relatively new players? -
100 Matrix DVD+R 4X Plus DVD Case Combo by shop4tech (MATCOMBO+4X)
I have burnt 90 and play this in 3 different players, only having problems with about 6 total that would not play in all machines. Burnt the 6 again and no problems.
Any one with a non working cyberhome dvr-1200 or 1600 will buy your remote
By therd3 in forum Newbie / General discussionsReplies: 0Last Post: 21st Sep 2010, 01:21 -
problem with cyberhome ch-dvr player/recorder
By kayjay3k in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2010, 17:27 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Need firmware for CyberHome DVR-1200 (MU)
By Man In Black in forum DVD & Blu-ray RecordersReplies: 7Last Post: 25th Jul 2009, 22:46 -
DVD Player Compatible with 2004 Pioneer DVR 220-S VR Mode of Recording
By iloveamerica11 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 17th Dec 2007, 12:14
