Ok I have these .mkv files and since I could not find no one to help me change them to svcd file I gave up on them(if you know how feel free to tell me) and decided to covert them with too .ogm files.
Heres what I did.
I used this guide to try to help me with this so you can see were I got this stuff from:
https://www.videohelp.com/forum/userguides/170944.php
I used VirtualDubMod to covert them to ogm files. Works good about the same size. So the quality is about the same.
I took the .ogm and used VirtualDubMod again and took out the audio and saved it as a Demux what makes it as a .ogg file. I have 2 audio file but I am not sure why I would need to put both in at the end since I want only the English.
Then I took it and I used a program called goldwave to covert the .ogg to a wav file.
Then I went to and used this program to convert it called EaseAudioConverter to convert it too a mp2 file. I tried this HeadAC3he but it never worked for me I got some weird error.
Then I took it and used TMPGEnc to try to put it together. But I get an error when I do that.(I am on step 3 of that guide I put up their)
Here is a picture of the error.
I have that file by that why what is says it is unable to load.
In case your wondering I need it too be scvd since my player plays that format. I hope someone can help me been trying for days now.
Also tell me step by step I am a noob as this. This is my first time trying to burn something to a cd. Let alone one of these 2 formats.
This is anmie too by the way. Also tell me if you want me to post more screenshot up about something and I will.
Ps. I hope someone helps me soon I am starting to think this can not be down.
you might try visiting matroska's website forum and see what you can find about converting their format to ogm.
might also try using gspot to analyze your source file - might find something there. -
You can certainly skip the one format conversion process to OGM. If you can convert your MKV to OGM with VdubMod, and this means that no RealAudio or RealVideo stuff was used for it, but maybe DivX+Vorbis or XviD+Vorbis, then you can also simply extract the Vorbis audio into a .ogg directly, no need to make an OGM first.Originally Posted by hoho12
About converting to SVCD, given the matroska playback pack is installed, TMPEGencoder can open those files ( but only those, it will fail on RealVideo or RealAudio stuff in mkv ) with its DirectShow import module ....
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
