i have the vob filews i wanna burn but vobedit isnt working like the guide says. whenever i try to join them nothing happens
Results 1 to 13 of 13
Try using VOB Merge to merge the VOB files and then continue with VOBEdit.
http://www.digital-digest.com/dvd/downloads/vobmerge.html
Also -- you can create IFO's for the merged VOB's using IFOEdit if you need. -
ok i downloaded that and selected the vobs i want. when i click merge what do i save the files as?
currently have the following files to merge....
vts_01_001.vob
vts_02_002.vob
vts_03_003.vob
vts_04_004.vob -
ok i renamed my files, got it to work and now i have a VIDEO_TS folder with several files. now what? how do i turn this into an iso?
I'll defer to an expert, as I do not know how to author DVD's (I do not even have a DVD burner). I have had to merge several VOB's and create IFO's, but only to convert to SVCD's via DVD2SVCD.
It could be as simple as CREATING a data DVD consisting of nothing more than the VIDEO_TS and AUDIO_TS folders. I just do not know.
Now that you are at this point, I'm of no use to you and will bow out!
You need to create an AUDIO_TS folder as well then add the two folders to the root of a UDF/DVD compilation in whatever burning software you're using and then burn the thing.
If that doesn't work, try screaming and running around in circles and then jump out the window of a very tall building. Sometimes that helps.
How To Add Subtitles to a DVD. (THE COMPLETE WORKING GUIDE).
By TheMatrixx in forum User guidesReplies: 653Last Post: 23rd Jul 2017, 02:40 -
DVD Hardware Guide: mp3 wma crossed out. Means unit don't read that?
By TomBrooklyn in forum Newbie / General discussionsReplies: 0Last Post: 4th Aug 2010, 07:26 -
DVD collection guide program?
By impmon2 in forum Newbie / General discussionsReplies: 0Last Post: 3rd May 2010, 18:19 -
ogm file with subtitles isnt working
By dudeboy in forum MacReplies: 0Last Post: 5th Sep 2009, 08:53 -
My Audio Isnt working, Dont know much about Audio, Just that my............
By UmmAddan in forum AudioReplies: 0Last Post: 12th Aug 2008, 20:11
