Hi all! I posted this in the general newbies section, but I thought I'd try it here as well -- my apologies to anyone who's already read it.
Let's say that I'm using a Canopus ADVC-100 to capture analog video, and then saving the file using Windows Movie Maker. When I run the avi through TMPGEnc, I end up with mpegs which are slightly shorter than the original avis (1-2 seconds), at least as listed by Windows Media Player. VDubMod is not detecting any errors in any of the original files, and the number of frames in the two files is identical...
Any idea what else might be causing this?
Thanks!
Jerry
Yeah, I think you're right. When I load the element streams into WMP, they are listed as being the correct duration, but once I mux them they start showing as shorter than they are. Well, solves that!
Thanks.
Audio duration change after transcoding from MP3 to MP2 or AC3
By darklock in forum AudioReplies: 3Last Post: 24th Feb 2012, 15:50 -
Finding out the duration of an MPEG file
By firblazer in forum ProgrammingReplies: 4Last Post: 20th Oct 2010, 01:55 -
Hard-Drive Recovery after Accidental Format with Other OS DVD
By jeanpave in forum ComputerReplies: 16Last Post: 21st Mar 2010, 12:59 -
Windows Media Player - How to change the still duration?
By coody in forum EditingReplies: 0Last Post: 6th Jan 2009, 23:37 -
Change of the still photo duration vs. increase of the No of pictures
By coody in forum Authoring (DVD)Replies: 2Last Post: 8th Oct 2008, 21:08
