I created an mpeg2 file SVCD using tmpgenc (CBR 2000). I then use tmpgenc to cut out some scenes. The resulting mpg2 file played ok with real and media player.
I then use NeoVisionExpress 1.x to author the SVCD. All works well except when I play it on my DVD player, it occasionally puts out blocks of various colors on the screen, very messed up.
I tried to use different media (TDK) and see the same. I then play the SVCD using intervideo WinDVD and media player and see the same problems.
Can I assume that NeoVisionExpress is messing up the mpg2 file during transcoding?
Not necessarily. First, try to burn at a slower speed. Next, change media brands, then, you may also try with another burn program other Ahead. Then you might start looking at your burner, provided it is the only burner you have available.
Hello. -
Did not thought of burning at a slower speed. I did tried different media:
imation (24x) and TDK (48x) with same result. Also, I have burnt before using this burner w/o any problem creating VCD discs.
burner causing problem with wireless internet
By zerocoool in forum DVD & Blu-ray RecordersReplies: 6Last Post: 6th Jan 2010, 01:19 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
problem in megui causing SHUTTING DOWN my computer !
By LOST World in forum DVD RippingReplies: 5Last Post: 15th Feb 2008, 04:45 -
Vdub audio filters causing problem on video track
By SearchQuality in forum AudioReplies: 4Last Post: 10th Feb 2008, 11:42 -
How do I, add chapters in Nero causing sync problem
By breeze9 in forum Authoring (DVD)Replies: 2Last Post: 22nd Jan 2008, 06:37
