  1. Just converted a movie using CCE (for the first time) and something strange happened. This is the way it came out:
    Here is what is in the .avs file I used:
    # -= AviSynth script by FitCD v1.1.2 =-
    #LoadPlugin("D:\PathOf\AnyPlugin.dll")
    AviSource("G:\The Woman in Black\The Woman in Black - no Audio.avi")
    ConvertToYUY2()
    BicubicResize(672,448,0,0.6,0,0,480,352)
    AddBorders(24,16,24,16)
    #Trim(0,182468).FadeOut(150)
    Also, this took me 14 hours for three passes. Any idea what's going on?
  2. Looks like your using the wrong codec. Use Gspot and if there is more than one codec on your pc to handle the avi, then remove all but one. It helps to know what your avi is encoded in, XVID, DIVX3, DIVX5???
  3. Don't know if this is the prob, but I was told always to put the ConvertToYUY2 line last. But if you have been doing it this way for awhile with no probs..then its probably not it, but I was throwing it out there.
