Hi all,
Any suggestions on a card (preferably with video card functionality that will do MPEG2 captures from TV and S-Video (SVHS)? I've tried the Hauppauge PVR 250 and the VIVO input on my GF4 Ti4600 but I'm not satisfied with the quality and the audio sync problems. Are there better options?
More info: I'd like to have finer control over the MPEG settings (motion parameters, VQ settings, etc.) than Hauppage provides, but I'd like to be able to capture in real-time (if possible) without losing frames or audio sync.
The system I'm using for this is:
2.4Ghz P4 with HT and 800mhz FSB
512MB ECC DDR400
160GB HD
GF2 MX 400 video
I'm currently considering the ATI cards, but am not sure what the MPEG2 performance differences are between the 7500VE/9600/9700/9800. Do these chipsets perform differently or is the encoding entirely software-based? I don't care about 3d performance, just capture quality and MPEG encoding.
thanks,
wade
Results 1 to 1 of 1
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
VHS/Beta Tuner MPEG2 from capture Card to Compress to Smaller File; HELP
By gauthijm in forum Newbie / General discussionsReplies: 1Last Post: 7th Aug 2009, 10:05 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
