DVD Writer Pioneer DVR A06. I cannot get my DVD writer to work!! the drivers have installed OK but my system says it cannot find the hardwear it is all connected ok I have set the jumper settings to Master. The error message reads "Driver installed OK cannot find hardwear (Code 41)" If I go into device manager and I can click on the device it is showing installed, but it has an
My DVD Rom is also showing the same since I installed the DVD writer. I have also unistalled and re installed with no success. My operating system is windows XP please help me it is driving me mad!!!!
Results 1 to 30 of 30
Stu Rob
I've problems in this sort of area with IDE Controllers using Microsoft proprietry drivers , you may want to use drivers from the actual controller or chipset manufacturer which tend in my own findings to be much more reliable , I am assuming that both your optical drives are connected to the secondary channel .
You have totaly lost me their. I don't know much about the inside of PC's
Stu Rob -
Well are both you DVD-ROM and DVD Writer connected to the same cable ?
Are both drives set to master , cos if they are that would be the problem you will need to set one of the drives to slave mode (preferably the Writer) and ensure that the drive set to master is plugged into the terminal end of the cable
Thank you for you patience with me. My DVD Writer is set to master and my DVD Rom is set to something else but not slave. I am work at the moment so I can't check sorry. Where will I find the terminal end cable?
Stu Rob -
Just make sure your dvd-rom drive is set to slave and keep your dvd writer set to master,dont worry about the cables.
The post above is quite right just change over your DVD-ROM to slave and all should be OK
Thanks to both of you for your help. I am very greatfull. I give it a try
Stu Rob -
By The way what is cable select my CD RW was on that before I removed and replaced it with the DVD writer
Stu Rob -
Cable select is the third option which selects whether the drive is master or slave depending on which of the two cable connectors you use . I've never used as it can cause problems .
Position on the IDE does not matter. It is essential that one drive is jumpered as the master and the second drive be jumpered as the slave.
Never put a HD on the same cable as a CD/DVD drive. CD/DVD runs at a much slower speed than a HD and the IDE channel will run at the speed of the slowest component on it. -
I have a dvd-rom on the same ide as my main hdd and both run at different speeds,udma 6 for the hdd and udma 2 for the dvd-rom.
Your all losing me again, you need to talk in basic terms, I don't understand is HD hard drive, what is HDD, Udma 6 & Udma 2
Stu Rob -
HDD is Hard Disk Drive and UDMA 2 and UDMA 6 are systems that the computer uses to transfer data from a drive to the controller , these are however not relevant to your current problem .
Stuart Robinson,one thing you have to watch for on the forums is that sometimes people talk about side issues that veer off from the main discussion.
I tried all that was suggested changed the jumper settings to DVD rom to slave and dvd writer set to master, but I am still getting the same error message. Please help!
Stu Rob -
Does your ribbon cable have a few wires in the middle of the ribbon sort of twisted anywhere on it? If so that is where the problem lies and you will need to replace the cable with a standard ribbon cable. These are only used when both drives are set to "Cable Select", a system not much used these days.
Artificial intelligence is no match for natural stupidity. -
Not that I have noticed it just looks like a standard ribbon cable. My system is only 18mths old so it should be quite up to date.
Stu Rob -
I had trouble with a couple systems that were brand new and would only work when both drives were set to cable select. Since your previous setup worked well with cable select, you might as well try it with your new settup. The worst that could happen is that it will not work.
That is how they were set up origionally not nowing much about Pc's I just copied the Jumper setting from the CDRW that I have now removed and it did not work.
Stu Rob -
Well, you should probably look at it instead of kinda guessing
It should be something like
C-M-S
S-A-L
Crude, but you get the idea.. I've never seen any real standard for them, and I"ve also never seen a drive NOT list its scheme, so you can probably figure it out if you take the drive out and look on the sticker or near the pins -
I have looked at it and have changed the Jumper settings as stated in postings
Stu Rob -
Stu Rob, Check to see if you have plugged in your cable correct. The plug at the end of the cable has one red wire on the end. The end with the red wire should be close to the power plug on the drive. maybe you have it flipped??? Check both of your drives. Hope this, or some other suggestion works!!
Good luck---DVDDave
Not to hijack the threadOriginally Posted by Duchess
Dell ships all their systems like this...#1 manufature of PCs, so I think it still used
I've even had some PCs from work that wouldn't even friggin boot up unless I set the devices to CS.. weird stuff
HELP PLEEEEEEZE! Pioneer DVR 111L Writer, Need Driver
By golfnut in forum DVD & Blu-ray WritersReplies: 6Last Post: 18th Feb 2010, 22:09 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Help with Pioneer DVD Writer DVR-112D and Nero
By tdoran70 in forum DVD & Blu-ray WritersReplies: 6Last Post: 1st Sep 2008, 17:23 -
DVD writer exchange for my Pioneer DVR-530H
By J.J.F in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2008, 10:40
