Hi
I'd like to know if I can :
1- Watch TV with it, if I use a composite/svideo out system
2- capture mpeg-2/mpge-1 using a software codec (what I understand is that it has Mjpeg hardware capabilities, but what about software capabilities?)
Thanks,
1. yes, you can. It can be watched on the monitor, or output to a tv/vcr, but the capture program must be running (but not nessessarily capturing)
2. I don't know of any. I have, thus far, been able to capture only to AVI. I wish I could
it would save a lot of time.
Thanks,
I have some other doubts:
- Can I capture uncompressed or huff. with DC10?
- I heard that capturing with Mjpeg for later converting to MPEG2 is not good because MJPEG is a loss process. What are your experiences, is MJPEG satisfactory, or should I look for lossless captures(what I think is not possible with DC10).
If you're talking about the MiroVideo DC10:
1-yes
2-no, only hardware mjpeg
Bye, MarioB79 -
DC10, are you referring to Studio DC10+?
If so, you can only capture with the Studio MJPEG codec (hw).
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 03:03 -
Software for S-video output on Pinnacle DC10 plus card(XP)
By Eightbitgnosis in forum Software PlayingReplies: 2Last Post: 30th Jan 2010, 09:33 -
Miro DC10 /DC10+ and fedora
By bmw524 in forum LinuxReplies: 2Last Post: 14th Nov 2008, 14:54 -
Pinnacle AV/DV2 or DC10+B miserable performance
By cybertheque in forum Capturing and VCRReplies: 1Last Post: 17th Sep 2008, 21:44 -
Pinnacle DC10 Plus on Windows XP
By Paulsa in forum Capturing and VCRReplies: 0Last Post: 3rd Apr 2008, 10:02
