hi, im new in encoding but i've already encoded some movies by following the directions stated in this site. recently, i've encoded the movie s.w.a.t. and what i don't know is, why are squares appearing on my movie during high motion scenes? is this normal because of the low quality of svcd? by the way, here's my settings:
Size: 720 x 480
Aspect Ratio: 16:9
CBR 1600 kbps
Encode mode: non-interlace
You obviously didn't do any reading.
Size: 720 x 480 is DVD resolution, not SVCD
Aspect Ratio: 16:9 are you sure? SVCD doesn't support 16:9
CBR 1600 kbps this is too low for SVCD, much less DVD resolutions
Encode mode: non-interlace DVD's should be interlaced, not non-interlaced
Now, what did you actually do? Convert DVD to SVCD or convert an AVI to SVCD or convert an AVI to DVD?To Be, Or, Not To Be, That, Is The Gazorgan Plan -
You might want to try using the SVCD template with variable bit rate. Also, if you look at the setting values for that template you'll see they're a lot different than what you were attempting. I'm sure even the SVCD template using CBR would be much better than what you ended up with. Either way, just experiment but try not to stray too far away from the template's settings.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 07:57 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
