I have a 4 hour MPEG2 video clip that I open for editing in MPEG-VCR. I mark several cut-in / cut-out pairs, clipping them to the Video Clipboard. Finally, I want to tell MPEG-VCR to save all these clippings (preferably, each clip into its own seperate .mpg file).
The help file says (I think) to use the "batch save manager" to do this. It says to save the clipboard list as a certain type of file, then reload the list and "batch save it."
I'm sure it is simple, but I cannot figure out how to do this. When I try to save the video clipboard, I have only one "file type" available (Project file). When I subsequently try to load this file into Batch Save Manager, it says something like "no files found."
All of the MPEG-VCR tutorials I've found only show you how to clip and save ONE cut in/out pair ... so mention of Batch Save. How do you do the batch save operation?
Shortly after posting the above message, I upgraded to the Womble Video Wizard. The batch manager in that program (along with information in help files) is very easy to figure out.
However, someone gave me the following information about using MPEG2VCR and so I'm posting it here, in case it helps someone elseo out down the line ...
>What you do is, you click on each video in the clipboard to open it,
>and press the save button in the new clip window. Enter a filename,
>and choose 'batch'. Then hit cancel. The clip is added to the batch
>window. Once you've added all videos, you hit go, and works a charm.
>Obvious when you notice it, but took me a while to figure out...
Womble Mpeg Editor help, please. Thanks.
By seymoria in forum EditingReplies: 9Last Post: 20th Sep 2013, 06:20 -
Tool to batch download, save and rename QuickTime stream files
By oediv in forum Video Streaming DownloadingReplies: 8Last Post: 24th Dec 2011, 17:24 -
How to cut and join DAT Video file with womble MPEG-VCR without conversion?
By kitharass in forum EditingReplies: 0Last Post: 11th Mar 2010, 12:57 -
Womble MPEG-VCR free today @ GiveAwayOfTheDay
By lordsmurf in forum Latest Video NewsReplies: 11Last Post: 25th Nov 2009, 06:05 -
Womble MPEG Wizard - Bookmarks
By terrypin in forum EditingReplies: 0Last Post: 18th Jun 2007, 13:45
