good god...where to start?
ok...i've got an AVI file that i am assuming was originally PAL...it's an uncut version of a film that was originally only released as PAL...so with that, i guess i am just assuming that the source file is PAL...
and when i try to encode it to MPEG/VCD, the audio and video arent synched correctly...so i tried to use this walk-thru to solve my problem...
https://www.videohelp.com/divxtovcd.htm
i ripped the audio with VirtualDub from the source file, and then i used the separated audio file as the audio source when i encoded the video to MPEG...
but the audio still wont match up with the video correctly...and in TMPGEnc, i have tried to encode the file as VideoCD (NTSC), VideoCD(NTSCfilm), and as VideoCD (PAL)...all with the same results...
in VirtualDub, i did the audio conversion with the sampling rate of 44100Hz...just like the guide said to...
now what i am wondering is this...is there a way to split the AVI before encoding it to MPEG? the way things are now, the MPEG that i make from the AVI - the audio and video match up fine through about half of the movie...but as the movie progresses, the audio gets faster than the video and happens before it is supposed to within the film...i figured if i could split the AVI first, and then rip the audio from each of those 2 AVI files and then encode the 2 parts separately with ripped audio and video source from part 1 and then ripped audio and video source from part 2, then it would synch correctly...
damn that's hard to explain what i'm getting at, and hopefully it makes sense...i'm sure there will be questions as to what i mean, so i guess i'll just wait for those questions to be addressed...
any help will be GREATLY appreciated...
ok...i'm kinda using this guide HERE right now...
in particular, the "do not frame rate conversion" in TMPGEnc with the video coming from the source and the audio that i ripped with virtual dub...
it's very similar to this OTHER THREAD that i found earlier, posted by someone else with a similar problem...i had already started to use the hints provided in that thread before you recommended the link that you did...but they are pretty similar, so we'll se how this turns out...
i still have a little over 2 hours before it will be finished, so i'll let you know how this works out... -
Originally Posted by Luke Vader
what i dont understand though is if the source is NTSC and i'm encoding to NTSC, why does the audio and video get out of sync? i've never had this problem with any other NTSC file, so why with this one?
PAL MPEG-2 to NTSC MPEG-2 - Different Color on TV
By HoosierGuy in forum Video ConversionReplies: 20Last Post: 5th Apr 2011, 12:43 -
Conversion from mpeg-4 ntsc to pal
By cagacayak in forum Video ConversionReplies: 8Last Post: 27th Jul 2010, 03:40 -
MPEG2 files - are they just MPEG, or are they either PAL or NTSC?
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2009, 15:07 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
