Hello to all, i am backing up another movie i have, The Matrix Reloaded, and the movie is 138 min in length. What birate settings do i need to configure?
Under this setting, I have all of the columns set to 2's and 1's and the CD size for all is 800 MB. I want this movie to fit to AT LEAST 3 CDR'S.
Do I need to set setting to 2 to 3 cds? My max average video birate is 2230. What about the audio of the SVCD? I used 224 for the audio birate, but does that take up alot of space of the SVCD?
No offense intended YoGotti, but why would you want to back up to SVCD and onto three CDs when with free ware DVDshrink you couold make a direct backup after re-encoding some onto DVD. Assuming of course you have a DVD / Burner. I understand if you don't although they are really comming down in price, expecially for internal IDE drives. Something to consider. As far as what bit rate to use?? Good question. Do you have a good bit rate calculator? Even with that, you never seem to get a good accurate setting verus final file size. Back when I was converting to DIVX, I had to try several times due the final file exceeding or falling too far under the CDs capacity. I used to use DVDx which would encode to MPG1 ( VCD ) - MPG2 ( SVCD ) and MPG-4 ( DIVX ) directly as the disk was being read. So basically it was a single step rather that have to first rip and then convert. As the file was being created it diplayed the estimated final file size which would fluctuate a bit depending on the slow versus fast actions portions of the movie.
Take careNo DVD can withstand the power of DVDShrink along with AnyDVD! -
Thanks, jtoolman, I really appreciate your response. Unfortunately, I do not have a DVD Burner, just a CD-R/CD-RW burner. My only option is SVCD. See, my problem is i let my brother borrow my DVD The Matrix Reloaded. I won't see this DVD in 2 weeks, but thank god, i ripped all of the VOB files off the disk. What DVD to SVCD programs will work with JUST THE VOB files? I know some progams such as Eazy VCD, require the actual DVD disc. Any help would be good. Thanks.
In the birate column of DVD2SVCD, i choose for first, 2 CD's, and i got 5 CD IMAGES AT THE END. The same for when i shot for 3 CD's, I GOT 5 CD IMAGES.
What am i doing wrong? By the way i am backing The Matrix Reloaded (4x3). The movie is 138 mins in length. What shoould i change in the settings of DVD2SVCD to get just 3 CD images? -
You aren't reading what the colums say, you have to change the times to match the movie to hit the correct number of CD's .
To Be, Or, Not To Be, That, Is The Gazorgan Plan
Sony TRV 138 or TRV 350: do these camcorders have "pass through"?
By tadd5181 in forum Video ConversionReplies: 1Last Post: 24th Apr 2010, 19:38 -
Looking for software to select 10 min clip from DVD
By jimdagys in forum EditingReplies: 3Last Post: 17th Apr 2009, 09:20 -
4 min movie conversion
By Tahir Ramzan in forum Video ConversionReplies: 2Last Post: 3rd Jan 2009, 01:46 -
why a dvd movie's length is longer than 120 min
By hzgg2 in forum Video ConversionReplies: 5Last Post: 5th Sep 2008, 19:20 -
5 hour movie on WMP, 90 min movie on MOVAVI
By jchockey in forum DVD RippingReplies: 0Last Post: 24th Aug 2007, 14:14
