I have a question to ask. I am somewhat in between the newbie status and dufus status. I just started using DVD author to convert mpeg to iso. Every mpeg I open with DVD author I get an error message that says the video sequence header is incorrect and is necessary for the GOP in a standard dvd. I encode with TMPGEnc. It there a way I can fix that problem when I am encoding with TMPGEnc or do I need a different decoder. I have used the MPEG tools in TMPGEnc and then did the merge and cut and did that way and it works great. Would just like to shorten up the process. Any help would be appreciated.
heres a little trick using tmpgenc.1 open tmpgenc 2click wizard off 3click file 4click mpeg tools 5click merge and cut 6click add (a window will open where you can load your file) 7 click output file(a window will open, where you can name your new file, and where to save it) 8click run, You are not actually merging or cutting anything, but it will correct the headers of your file.
can't get ffmpeg to convert video to image sequence
By wiseant in forum Video ConversionReplies: 15Last Post: 12th Apr 2013, 08:37 -
DGindex "NO video sequence header found"
By JackDanielZ in forum Video ConversionReplies: 4Last Post: 28th Apr 2012, 08:41 -
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 11:23 -
No sequence header on two vobs after authoring in Encore CS3
By Killer3737 in forum Authoring (DVD)Replies: 1Last Post: 7th Feb 2009, 07:30 -
VIDEO TS sequence
By red lion in forum EditingReplies: 1Last Post: 25th Jun 2007, 19:15
