Hello
Have some trouble running VCD discs on my DVD player. I have burned a VCD disc with Nero Burning Rom 5.5 and when I put it in the DVD player (a HK DVD 30) it displays the folder structure and searches within the folders without finding anything. No files are visible within the folders. I cannot play the VCD disc and I have tested that same disc on a pioneer an a centrum DVD player where it works fine.
Anyone recognizes this problem and has a solution?
/Moorstream
assuming your player is a set top model, you might want to check it's owner's manual to see if it was desigend to play vcd's. Some dvd players do not.
Yes, DVD 30 can handle both VCD and SVCD. There is a VCD icon in the DVD-players display that lights up when inserting the disk, but it doesn't play. The manual is not very helpful regarding this problem either.
/Moorstream -
The only thing I can suggest is to try using a different authoring application such as vcdeasy. Worth a shot ?
All Harman Kardon (including DVD49) region hacks
By RunaruR in forum DVD & Blu-ray PlayersReplies: 7Last Post: 11th Jul 2020, 20:59 -
Harman Kardon DVD-22 won't open the disc tray
By edong in forum DVD & Blu-ray PlayersReplies: 0Last Post: 13th May 2011, 17:11 -
Harman Kardon DVD 48 Region Free Hack
By silverbullet763 in forum DVD & Blu-ray PlayersReplies: 14Last Post: 30th Apr 2010, 05:39 -
harman kardon dvd28 - problem with dealer mode
By straightedge in forum DVD & Blu-ray PlayersReplies: 1Last Post: 18th Dec 2009, 00:22 -
Harman Kardon DVD 49 region free
By torquemonster in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th May 2009, 11:08
