  1. Anonymous
    Guest
    Over the Christmas break, I had a lot of spare time to play around with ffmpegX, and noticed that when converting divx/ogm/avi to DVD, the mplex stage usually bombed out if the input file produced a combined .MPG greater than 2Gig. The default setting for mplex is 2Gig, which was causing the problem. After such a crash, I found that the separate Mux feature worked fine and created the DVD directory structure etc..
    So it seems that the default 2Gig limit is over-ridden in the Tools section but not in the main process...
    W.I.Bler
  2. I will fix this in next version. By the way, did you set "DVD 4GB" as media size in the video tab?
  3. Anonymous
    Guest
    Yep!,
    I have done the DivX to DVD conversion on around 5 films over the Christmas break, and the only one that went right through from start to finish was a 1 hour documentary that produced a .MPG file of 1.95Gig. All the rest were between 2.4Gig and 3Gig, and stopped during mplex. runing Mux from the Tools panel picked up were it left off on each..
    W.I.Bler
